SS LTD Roundhouse
Started by sdrees, June 23, 2019, 10:51:33 PM
Hey Steve:
I'll be following along.
sdrees
I spent some time today working on the floor for the roundhouse.  I added a piece of 1/8" foamboard to the bottom of the 1/2" Gatorboard to add thickness to the base so that the inspection pits will be 5' deep.  Also, since I am using code 70 rail, I had to add a 6x6  underneath where the rail will be placed because the floor material furnish is .10" thick and I am going to cover the floor furnish with the kit with Monster Modelworks Cracked Jointed Concrete as shown in the picture
Steve Drees
SP RR
sdrees
Glad to have you follow along Karl and Curt!
Steve Drees
SP RR
Great choice for flooring!  At one point I was talking to Jimmy about "end block" laser-cut sheets, but we agreed there was probably not enough demand for that product.
The SS Ltd kits are great designs, modern materials will make the model even better.
sdrees
Continued work on the floor. I've got the  cracked jointed concrete glued down and the inspection pits walls lined with the formed concrete sheets.  I have been experimenting with the finishing of the floor as you can see in the lower corner. I used 3M spray adhesive to glue down the floor material
Steve Drees
SP RR
Hey Steve:
Great job on that concrete floor. Can't wait to see it finished.
Something to try for the floors:  Get some charcoal, crush it, and just smear the charcoal dust all around.  Then use some gloss medium in a couple spots to reflect water or grease spills.
Steve,
Great job on the floor, looks very good.
Dennis Bourey
It is looking great!!!!!!!!!!!!!!
Dennis Bourey
dpbourey@comcast.net
Lake's Region RR
(Happy Modeling)
Steve, nice choice for the flooring on this structure. It looks great.
--George
sdrees
Thanks everybody for your comments on the floor.  I have to confess that I screwed it up when I was trying to finish it.  Fortunately, I have extra flooring and will try again.
Steve Drees
SP RR
sdrees
I took the die cut wall and used it for a template for the side walls made out of the monster modelworks cut stone and brick.  I had the laser cut material made from 1/16" basswood instead of the 1/8" material that is his standard product.  So when the brick and the cut stone material is glued together, it is the same thickness as the window casement castings.
Steve Drees
SP RR
The brick looks really good.
That is going to look so much better than the pressed paper stuff.  So the walls will have a stone exterior and a brick interior?
