You will notice from the background of the pictures that I have spent some time getting my workspaces organized.  I have things setup so I will have have three main build areas and two smaller workbenches for subassemblies and small projects that come up. I'm sure I will be making a few changes as we go but so far I really like the new workspace.
Quote from: PRR Modeler on November 01, 2019, 07:26:03 PM
I really like the look of the stone work.
Curt
I agree, George did a great job with these stone walls. I will be coloring them with a variation of brown similar to what I did for the Foundry build.
I did a test sample with the coloring technique I plan to use for the wood siding on Swakhammer's.  This is stained with Hunterline Yellow Cream and then a wash of A&I to make the grain and nail heads pop. I used one coat of stain on the top third of the sample, two coats in the middle, and three coats on the bottom. This building is going to be located in a yard with lots of steam locomotives running around it. The plan is to use different numbers of coats of the stain in different areas of the walls to help give it that weathered look.
I also started gluing the bracing for the clapboard walls on the Fox Run Milling build. The rest of the day was spent preparing the detail castings for both builds.
John really like the coloring and the way the weathering is showing up.
Quote from: Jerry on November 02, 2019, 08:53:37 AM
Thank you - I will probably add a little chalk for texture on the model but this is the way I plan to go on this one.
Looking good, John.
That cream colour is nice.
engine909
Yellow cream is very nice. I just used it on the John Allen Engine House O scale kit from Mt. Albert.
Quote from: mark dalrymple on November 02, 2019, 01:59:48 PM
Looking good, John.
Thanks for stopping by the thread.  I have a dark brown picked out for the windows and doors that I think will look good with this yellow/cream.
Quote from: engine909 on November 02, 2019, 02:15:17 PM
I bet that really looks good. I'm really liking the way the Hunter Stains work so far.  Up until my big purchase of their products at the Narrow Gauge Convention I had only tried the driftwood and cement colors.  As with everything I do the stain is the base color the A&I brings out the details and then I usually hit it with some chalks as a finishing touch.
Update: The wall bracing and corner moldings were added to the Fox Run wall sections today. I also prepared the detail castings for Swakhammer's - I have a few more to do in the morning and they will be ready for the paint booth.
The castings for Swakhammer's are ready for the paint booth.
The FSM NBW castings always looked too large to me.  On my Jacobs Coal, I used Tichy castings instead.
