F&SM G. Brill Co Scratchbuild
Started by SteveCuster, January 28, 2019, 04:13:48 PM
Raymo
Great job on the modeling and you nailed it with the detail parts.
Was watching an old Allen Keller video on the F&SM, and there was G. Brill! :D
SteveCuster
Thanks everyone. I haven't seen that video in a long time but I remember borrowing it from my local hobby shop on VHS. I think George does a little clinic on signs and weathering flextrack on that video as well if I remember correctly.
I'm not quite done yet. I got the base laid out this morning.
First step was trying to figure out the elevations. This diorama will live right next to the other 3 I just built. Once I'm done this one I will run the road down the front and connect it to the dirt road in front of the casket company.
I modified the top layer and cut out a chunk of the third layer for the concrete base. I also accidentally pulled the main building off the base. No big deal to glue back on and it made it a bit easier to work the base.
I placed a few small rock castings around the scene. I have a few rock molds from Bragdon I use. They are large molds so I fill them and once they are dry I wrap them in a towel and drop them on the floor till they break into smaller pieces. Then I pick pieces that fit whatever I'm trying to use them for. It's very precision stuff.
I colored the rocks with some black and brown thinned out and spread some plaster over the diorama. After I mix my plaster I squirt a bunch of cheap brown craft paint into the container to give it a brownish tint.
The area in the front will be where the road will be. Once everything dries Ill start adding the scenery.
-Steve
Steve Custer
How cool watching this come together!👍🏻👍🏻👍🏻
Hey Steve:
WOW!!!!!!  Beautiful job.
Very cool. I've never used foam so this is different for me.
SteveCuster
Thanks everyone!
Small update today.
I started putting down the first layer of scenery today. Still wet in this photo so it'll lighten up a bit. I felt like the hillside to the left of the structure needed something so I started building a billboard for it.
The rear of this billboard will not be seen on the layout so I kept the construction pretty simple and easy. I cut out a sign and glued it to some chipboard backer.
I framed out the sign with some scale lumber. I used what I had sitting on the desk that I had already colored. I think they are scale 2x6s.
Some posts glued in place.
A few front supports.
The good thing about using foam as a base is I just poked a few holes in it with a small drill bit and pushed the sign in place. I'll add the rear supports once the glue and scenery dries.
I need something for the area to the left up top. The area will be up against the tracks but it looks very empty to me. Maybe a water tank or some trackside sheds.
-Steve
Steve Custer
SteveCuster
Thanks Curt.
I made some progress on filling the area in the rear of the diorama yesterday.
I built this little shed to fill the area. I didn't want anything too complicated because the area will be difficult to see from the front of the layout. I colored the walls with Apple Barrel Pavement.
Test fit to see how it feels.
Added the roof and rafter tails.
I thought the area around the shed was too plain. I built this little coal bin with some scrap wood I had on the bench. The base for the coal pile is a piece of blue foam painted black and sprinkled with cinders.
I added some scenery and a few details to the area. I also added more coal to the bin.
It looks more complete to me now but it still needs quite a bit of detailing. The ground cover is still drying in this photo so it should lighten up a bit.
I started to work on the front staircase last night but in the process I broke off the whole front loading dock. I got everything back in place but I didn't want to mess around the area anymore last night. I'm going to try to get the stairs put together this afternoon and add some of the detail parts.
-Steve
Steve Custer
restocarp
A+ work, Steve. A simple but beautiful addition to the scene.
Matt
rpdylan
yes, nice work Steve!
    I see, like me, you use the Gallery Glass liquid leading!
Bob C.
richbeau
Wonderful work on G. Brill!
I remember that building from my first visit to F&SM during the 1986 NMRA Convention.
And thanks for using graph paper  ;)
--Rich
NKP768
Great looking build Steve - didn't George use the original building to cover an above ground switch machine?
Doug
