FSM Fox Run Milling - scratch/kit bash
Started by ACL1504, September 02, 2019, 05:50:34 PM
Quote from: S&S RR on September 03, 2019, 05:16:31 PM
I will be following along.  Fox Run is the next build on my list "from the kit" - I will be getting started when I get back from the Narrow Gauge Convention.
Thanks, I saw in person the one Reading Bob did for Seckler. Beautiful. But I don't have the space for that size and I can't remember ever seeing any coal docks in Central Florida. I never met an FSM kit I didn't like and through the years I grew out of the need to have them all, needed or not.
Quote from: DennisBourey on September 03, 2019, 07:46:34 PM
Can't wait either...........Dennis
Dennis,
I'm with you, I can't wait to finish it and get it planted.
Quote from: Raymo on September 04, 2019, 05:10:03 PM
Sitting here with the group watching this one go together.
Dan,
Thanks, I hope you found a good seat on the fence.
The end wall, the one facing the overhang on the full size kit, didn't have much detail. Since this wall will be seen, I added four windows.
To make sure I got them in the correct position (centered), I placed one window on the rear of the wall. I marked the location and then divided the wall into four windows. I marked the center of the wall in pencil and then marked the center line left and right of the center center line.
I then marked the window locations and drew horizontal lines above and below the window location.
When satisfied, I remeasured and marked in red the cut lines as shown in the photo below.
All door and window opening are now cut.
Here are several views of where the building will be located. Some photos were taken with the LED overheads on and some weren't.
I wanted to see it both ways.
Continued -
dick green
Treat build tom. I'm already picking up some great tips I'll have to reread the one about the window placement, not sure I really get it yet but I'll read it again.
Dick
Dick
Apple Valley, Mn
NKP768
Quote from: dick green on September 04, 2019, 11:58:02 PM
Dick
Dick,
Thank you, appreciate you following along. I guess I blew through the narrative on cutting windows. I've done a little more work, with paper,  and I'll go over it in more detail in a later this morning.
Quote from: NKP768 on September 05, 2019, 08:37:30 AM
Looking good Tom -
Doug
Doug,
Thank you, much appreciate you following as well.
I'll go into a little more detail on how I center and then cut in windows on a scratch build.
I'm using a piece of copy paper so I don't waste any wall material.
Here I've cut a piece of paper the same size as the wall section.
I place windows or doors on the wood to determine where I want them located. In this case I want four windows, two on the bottom and two on top. I also want them centered.
Continued -
