FSM Fox Run Milling - scratch/kit bash
Started by ACL1504, September 02, 2019, 05:50:34 PM
Well, I forgot about measure twice and cut once. I then spent about 40 minutes looking and studying on it.
I then cut a new roof panel and started over. I drew lines on the new roof panel using the dormer roof panel as a guide.
I then cut the main roof panel along the lines and made another test fit.
Continued -
Not perfect but it is in the bubble lines. Not bad for a second try and I got lucky. Murphy has nothing on me this time.
After taking the photo, I realized the dromer slid down a bit from the fifth wall.
Yepper, more in a few.
I then added a dry brushing of A&I Light Gray to the walls.
I dipped a 1/2" soft brush into the A&I, dabbed it on a napkin and then quickly dry brushed the light gray on the walls. I used horizontal strokes for the brushing.
Continued -
I used a pencil to mark the location of the small office.
Glued some cardboard to the rear of the window openings.
Continued -
Painted the area with Tamiya Flat Black.
Raymo
Tom, this is looking great. I see more and more of us gravitating to the Tamiya paint. I use to use it more in my model car building days 30 years ago. I might need to build up my stock again.
Bruce Oberleitner
Uncle Tommie,
Mighty fine work on your scratch building efforts my friend.  Keep up the good work.
BTW, say "Hi" to the Judge for me.
;D ;D :o
Hey Tom:
It's coming along just great. Sent you A PM today.
fsmcollector67
9 Fingers Loren.....
Quote from: Raymo on September 17, 2019, 07:20:00 PM
Dan,
Thank you, much appreciate you stopping by for a comment. I really like the Tamiya paints. However, I've only used them on wood building but plan on trying them on some Sylvan's in the new year.
Quote from: Bruce Oberleitner on September 18, 2019, 12:11:04 AM
Uncle Tommie,
;D ;D :o
Cousin Brucie,
Thank you my friend. I'll pass on the message.
